Author Topic: my golf mk4 1.8 t has more faults than i can deal with  (Read 1381 times)
Offline bensimm91
First of all air bag failure message pops up on screen but no lights ? .. the passenger side wont open from the inside .. stereo requires code in safe mode .. interior lights dont work .. centre console is falling to pieces can anyone help me with any of these it runs fine aswell but its got mot on friday so need to get some of these sorted out
Offline MoMartin
Passenger side door should be an easy fix, it sounds like you just need to reattach the cable to the handle. You do this by removing the door panel, then once you're in there there will be a cable with a hook on the end of it. You need to reattach that to the handle (a bit of plastic with a hole in it)
As for the airbag you will have to get someone to remove the fault code using vag com, and hope it stays off until after the mot, as that is an instant failure I believe.
No idea what you can do about the rest
Good luck, Mo
Offline northeast_gti-t
  • "1.8T AGU"
As already suggested for your passenger door most likely a disconnected cable,as for the airbag no light i would be tempted to remove your cluster and check to see if the l.e.d for the airbag warning light is not covered i recently replaced my cluster with an immo3 cluster and once coded in etc i noticed no airbag warning light i could tell the cluster had been apart at some point (speedo needle out of pos  :wink:) and as i was fitting my painted needles i pulled it apart and found a previous owner must have had an airbag light fault as the l.e.d warning light had been covered over  :laugh: centre console is an easy replacement and you can find a few on e-bay,interior lights not working could be bulbs fuse etc or a faulty door lock module if you have use of vag-com it will flag up any fault codes you have
2000 Mkiv GTi 1.8T AGU
