Author Topic: Permanent light illuminated  (Read 1946 times)
Offline JoseMcGeevio
« on: 25 May 2014, 13:46 »
Alright guys,
I have a mk3 8v anni,
The ABS, HANDBRAKE & only sometimes the AIRBAG lights illuminate
Any ideas what this might be?
Ive read a few things but I'm not sure,
My car only revs unto 5000 rpm then restricts any more, but if i key pop it it will rev to 6500+
Is it going into safe mode?
Any clues?!
VW BUSH
Re: Permanent light illuminated
« Reply #1 on: 25 May 2014, 15:24 »
Scan it.....
ABS light stays on when there is a sensor out
ABS and Handbrake light staying on could be ABS ecu fault
Airbag light staying on is a fault.
5k rev limit is safe mode, timing is out or hall sensor is dead, check timing
Scan it......
Offline snozan
« Reply #2 on: 25 May 2014, 15:30 »
Scan it.....
Scan it......
If ABS lighht stays on and you get fault code for left rear or front, its the ABS hydraulic pump that is broken.
And this is the problem. (VW and Volvo share the same ABS system, so the fix is the same: http://www.volvoforum.no/tips_triks/850-absmodul.htm
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
« Reply #3 on: 25 May 2014, 17:12 »
I forgot to mention though that when i key pop it the abs light,airbag light and handbrake lights all go off,
Its really burning my head out,
Offline Therusterman
« Reply #4 on: 25 May 2014, 18:53 »
As said, get the fault codes read then you'll have an idea what your dealing with
