Author Topic: Need to change the bootlid  (Read 1674 times)
Offline Scottymk4
« on: 25 May 2014, 11:16 »
As the title... Need to change the bit, how hard a job is this to do?
Offline dom
  • Back in a Mk4
Re: Need to change the bootlid
« Reply #1 on: 25 May 2014, 11:23 »
Offline Scottymk4
« Reply #2 on: 25 May 2014, 11:27 »
Thanks dom
Offline Scottymk4
« Reply #3 on: 25 May 2014, 19:38 »
Anyone know where I can get an 8mm multi thread wrench? For taking the hinges off a bootlid
« Last Edit: 25 May 2014, 20:04 by Scottymk4 »
Offline brewey
« Reply #4 on: 25 May 2014, 21:28 »
If your replacement boot has got the hinges on I would drop the headlining at the rear of the car and unbolt it from there rather than leaving the hinges attached to the car. I'm sure that's what I did with mine.
2000 1.8T ARZ - OEM+
Offline Scottymk4
« Reply #5 on: 25 May 2014, 21:51 »
Unfortunately the replacement doesn't have the hinges... Didn't notice till I took the old one off
Offline brewey
« Reply #6 on: 26 May 2014, 10:27 »
That sucks, best of luck then mate   :smiley:
Offline Scottymk4
« Reply #7 on: 26 May 2014, 16:10 »
All on now just need to get the lock changed over and get it locking through central locking
Offline brewey
« Reply #8 on: 26 May 2014, 16:47 »
Good work pal. :).
Offline Scottymk4
« Reply #9 on: 26 May 2014, 17:48 »
Cheers mate was a bit if a hassle as realised it didn't have any of the bits for the central licking so had to change part of the loom and some if the lock bits.... Only problem was I had to split one of the rubber boots that covers the wires so need to come up with a fix for that
