Author Topic: intercooler cleaning question  (Read 2464 times)
Offline viperjsy
« on: 24 May 2014, 23:04 »
hi just wondering if the intercoolers insides can be cleaned as my boost pipes have a oily residue on them
« Last Edit: 24 May 2014, 23:07 by viperjsy »
Offline Rhyso
Re: intercooler cleaning question
« Reply #1 on: 24 May 2014, 23:07 »
hi just wondering if the intercoolers insides can be cleand
Yup. Good blast with the pressure washer can do the trick
Id recommend removing from the car first though and drying it thoroughly before refitting  :wink:
Offline viperjsy
« Reply #2 on: 24 May 2014, 23:07 »
the insides? and sould I use a degreaser to clean any oil residue out
« Last Edit: 24 May 2014, 23:09 by viperjsy »
Offline Rhyso
Offline viperjsy
« Reply #4 on: 24 May 2014, 23:43 »
will give that a go some time thank you. or should I get a fmic . my car is standard
Offline dom
  • Back in a Mk4
« Reply #5 on: 24 May 2014, 23:46 »
Unless you're going for stage 2 power then I wouldn't bother.
Offline viperjsy
« Reply #6 on: 24 May 2014, 23:51 »
ok thank you dom
Offline dom
  • Back in a Mk4
« Reply #8 on: 25 May 2014, 11:03 »
It really does depend on the power you are going for, a stage 1 map will work fine with your standard SMIC. That kit will need your bumper to be cut in order to fit it.
Offline viperjsy
« Reply #9 on: 25 May 2014, 22:04 »
ok thank you dom
