Author Topic: Realistic brake upgrade for mk6 gtd  (Read 16540 times)
Offline Beddie
Re: Realistic brake upgrade for mk6 gtd
« Reply #30 on: 25 May 2014, 18:15 »
Ok so in a road car you use daily is there a fluid you could use thats better than standard but has the same validity
I'd just stick with the OE fluid changed once a year, the stuff that the dealer puts in a Golf is exactly the same as the stuff that goes into a Ceramic braked Audi R8, done via the dealer for £59 with a proper ABS pump purge done via VCDS it's one of the only bargain jobs done via a main dealer imo  :smiley:
Carbon Grey ED35
Offline Mattyj
« Reply #31 on: 25 May 2014, 18:27 »
Abs pump purge??
Offline Beddie
« Reply #32 on: 25 May 2014, 18:32 »
The only correct way to do a full fluid change on the mk5/6 is to use VCDS or dealer VAS to cycle the ABS pump to remove all of the old fluid and to prevent the introduction of air  :smiley:
Carbon Grey ED35
Offline Mattyj
« Reply #33 on: 25 May 2014, 18:58 »
Every days a school day
Offline RocketRossUK
« Reply #34 on: 25 May 2014, 19:58 »
All of what Beddie has said is correct. I always take mine to VW for brake fluid change.
The OEM stuff is great unless you are doing a lot of track day where your brakes it be getting super hot.
Beddie - do you use 5.1 as you track a lot?
Offline Mattyj
« Reply #35 on: 25 May 2014, 20:20 »
 ?? I never said he was wrong?
« Reply #36 on: 25 May 2014, 22:42 »
Lool, I was merely agreeing with him, like nodding my head in conversation, not that you we're wrong  :tongue:
Offline Mattyj
« Reply #37 on: 25 May 2014, 22:46 »
Lol haha ok mate thought you thought i was being sarcastic
Offline Beddie
« Reply #38 on: 26 May 2014, 13:41 »
In my old ed30 I always ran Motul RBF600 which is a DOT4 fluid, reasonably cheap and has a dry/wet boiling point higher than quite a few DOT 5.1 fluids, probably had 3 full fluid changes using that and couldn't fault it tbh, since though I have always ran OE fluid changed by the dealer and stuck to once a year or after every 2 track days and it's been spot on tbh  :smiley:
For the cost of RBF600 alone I can have the OE fluid supplied fitted and bled and fresh fluid seems to make the most difference in feel terms imo
Carbon Grey ED35
Offline Mattyj
« Reply #39 on: 29 May 2014, 18:09 »
Can't get hold of any of the guys that supposedly supply these brackets any help?
