Author Topic: LSD  (Read 2062 times)
Offline meg1980
LSD
« on: 24 May 2014, 11:34 »
Hi there does anybody know how to identify whether a gearbox has a LSD without fitting it. I have a 020 box and been told it has one. But would like some information as to whether information is correct. Cheers.
i was told the 020 rod box was supposed to be a strong box,how wrong are they 5 and counting on my mk2. Hopefully the quaiffe box will last.
Offline tweed
Re: LSD
« Reply #1 on: 24 May 2014, 15:55 »
Both axles will turn the same way.
Try turning it on one side and if the other sides turns same direction then lsd  :wink:
Offline dom
  • Back in a Mk4
Re: LSD
« Reply #2 on: 24 May 2014, 16:09 »
As tweed says, you need to jack the car up and spin one wheel. If the other wheel turns in the same direction it has a LSD, if it doesn't then it'll be a standard diff.
Offline matt@onlychargeddubs
Re: LSD
« Reply #3 on: 28 May 2014, 16:07 »
Not always as simple, some boxes/factory diff's may spin both wheels the same way still.
I'd just pop the CV cups out, you'll be able to see if it's a factory open gear or not for sure
