Author Topic: Golf mk3 eibach pro kit and bistein shockes raised front  (Read 3147 times)
Offline WeekendMechanic
  • Golf MK3 GTD
I bought the pro kit and a set of bilstein TC`s the rear looks low and nice but the front is slightly higher than stock what gives? people are telling me its because the bilstien tc`s are gas monotube did i get the wrong shockes?
Re: Golf mk3 eibach pro kit and bistein shockes raised front
« Reply #1 on: 21 May 2014, 11:00 »
Could be the wrong front springs
  • Golf MK3 GTD
« Reply #2 on: 21 May 2014, 12:18 »
no they came as a kit same part number and correct springs also installed correctly
Offline clancy
« Reply #3 on: 21 May 2014, 13:17 »
Did you get the sport or comfort package ? They sit at different heights, although neither should be above stock. What's the spring rates ? Also are they installed correctly.  And bilstein don't really make their kits for lows if that was the end goal
MK3 GTI 16v
  • Golf MK3 GTD
« Reply #4 on: 21 May 2014, 16:20 »
they are the pro kit Spring rate is 950kg front 840kg rear my goal was to close the arches a bit
