Author Topic: golf mk2 16v rolling shell (drive shafts in or out?)  (Read 2883 times)
Offline Shivas Regal
Hi guys just stripping my mk2 ready for body shop. Want to be able to transport car easily. When removing engine and gearbox do I have to leave the driveshafts in at the hub end for it to 'roll'
If I dont need driveshafts in  I was thinking I could remove shafts from hub end only and lift engine, gearbox, driveshafts out together?
Thanks in advance
Shiv
Offline h8v
Re: golf mk2 16v rolling shell (drive shafts in or out?)
« Reply #1 on: 21 May 2014, 10:29 »
If you want the front wheels to stay on, you will need the outer CV joints in place and the hub nut on!
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 21 May 2014, 10:57 »
you can move them without driveshafts, but it's a lot harder to push around. Best cable tie them out of the way to the brake lines or something.
Mk4 Golf 150PD
« Reply #3 on: 21 May 2014, 11:03 »
Leave the driveshafts in but tie them out of the way.
« Reply #4 on: 21 May 2014, 11:35 »
Thanks guys...so the consensus is to remove driveshafts fro gearbox...hall engine and gearbox out then cable tie driveshafts out of the way?
« Reply #5 on: 21 May 2014, 13:39 »
Yes that will be fine
