Author Topic: cambelt & water pump  (Read 3469 times)
Offline Mark b
« on: 21 May 2014, 06:32 »
can anyone recommend where I can buy the cambelt and water pump kit from as mine is getting close to changing
Standard gti 2.0 115bhp 2000 w reg
Offline Nino
Re: cambelt & water pump
« Reply #1 on: 21 May 2014, 06:56 »
Always get OEM mate do NOT use cheap parts
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 21 May 2014, 07:45 »
Trade parts specialist (TPS) oem but cheaper than dealers.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #3 on: 21 May 2014, 10:33 »
Or try BoneyBradley on here :wink:
« Reply #4 on: 21 May 2014, 11:06 »
A kit from Gates is another option
Offline Dalo Harkin
« Reply #5 on: 21 May 2014, 12:42 »
isn't it also worth doing the engine mounts at the same time?
Offline dom
  • Back in a Mk4
« Reply #6 on: 21 May 2014, 12:59 »
Not the mounts themselves, but bolts are recommended.
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 21 May 2014, 14:36 »
you only renew them if you take the mounts off??
*****MK4 GTI T*****
Offline Mark b
« Reply #8 on: 21 May 2014, 15:21 »
just called tps they will do the cambelt kit and water pump for exactly £100 if I give them my old pump
Offline mcgee9t2
« Reply #9 on: 21 May 2014, 16:03 »
this is what i have on mine, good quality and werent that expensive irrc.
