Author Topic: Poor quality radio signal?  (Read 2030 times)
Offline jonnyb
« on: 19 May 2014, 21:46 »
I've got a mk5 gti, and one thing which p!sses me off is the radio signal.I can pick up Radio 1, and thats about it.  everynow and then i can get a few extra stations, but often lose them as i drive.
Any thoughts?
Offline bacillus
Re: Poor quality radio signal?
« Reply #1 on: 20 May 2014, 17:49 »
Are you using the standard external aerial?
Without traction power is nothing!
Offline Bandit127
« Reply #2 on: 20 May 2014, 19:29 »
And are you using the original head unit?
Offline jonnyb
« Reply #3 on: 21 May 2014, 13:28 »
The car is running an RNS510 satnav unit.  To my knowledge this also uses the standard aerial.
Offline Bandit127
« Reply #4 on: 21 May 2014, 18:20 »
This is a bit of a shot in the dark but I had a similar problem and an A4 Avant.
That had 3 aerials. One on the roof, one in the heated rear screen and one on a rear side screen. There was an amplifier/control unit that would pick the best reception and boost the signal. (Diversity module). It needed a 12V supply. (On that car the 12V wasn't supplied by an aftermarket head unit - not your problem but maybe part of your solution).
The reception on that was very much like you describe. I would check your fuses and maybe get it scanned.
Offline jonnyb
« Reply #5 on: 22 May 2014, 11:15 »
I've got the cables and stuff to do my own scan.  I do know at the moment the CAN gateway isnt quite setup correct, which i do need to sort out, but i dont think its the issue with the signal.  Perhaps i should get my @ss into gear and sort that first, then see if there are any more fault codes hanging around.
Thanks for the input btw
