Author Topic: is it safe to run car stage 2 with no fmic (temp)  (Read 1829 times)
Offline davemk4
Looking at the amd remapped ecu mods all ready are
Tip
Induction
3`` downpipe decat
2.75" cat back
Forge 007 on yellow spring
So the ecu looking at is 221bhp was mapped with a fmic. I know i wont retain that peak power due to heat soak but is it safe to use while i sort out my fmic route??
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Bandit127
Re: is it safe to run car stage 2 with no fmic (temp)
« Reply #1 on: 19 May 2014, 18:19 »
I reckon the ECU you are looking at has a Stage 1 map. 210 bhp is par for the course in standard trim (i.e without FMIC).
So yes, it will be fine  :smiley:
Edit. Just read your sig and see you have a stage 1 map. Yours should already be making at least 210 with the decat and probably more like 220. What do you think this new ECU is going to do for you?
« Last Edit: 19 May 2014, 18:26 by Bandit127 »
Offline dom
  • Back in a Mk4
« Reply #2 on: 19 May 2014, 19:14 »
I disagree, a stage 1 map is around 190-200bhp.
221bhp is perfectly realistic for stage 2 depending on the level of mods.
Offline davemk4
« Reply #3 on: 19 May 2014, 20:06 »
Im at 185bhp but map just generic
Offline Chris.
« Reply #4 on: 20 May 2014, 01:09 »
you NEED a FMIC for a stage 2.  The turbo gives off too much heat and the stock SMIC intercooler cant keep up with anything over 200bhp and wanting to push stage 2 mods.
If your going to go stage 2, do it right and get a FMIC and take full advantage.   Last thing you want is 50C+ temps pulling timing so far back your still at stage 1 power.
Click For Build Thread
Offline LittleReDuck
  • '98 180bhp MK3 1.8T and Loving It
« Reply #5 on: 20 May 2014, 10:24 »
If its at a good price why not get the ECU and store it until you've sorted the FMIC route?
VR Died...Now running MK3 Golf 180bhp 1.8T
Offline mcgee9t2
« Reply #6 on: 20 May 2014, 12:36 »
above,
or install the ecu and just drive sensibly (i.e. not ragging it) untill you get fmic sorted.
Offline rio_gti
« Reply #7 on: 20 May 2014, 13:24 »
above,
who can resist boosting thou!!!
Offline davemk4
« Reply #8 on: 20 May 2014, 20:03 »
I dont mind loosing power due to oem side mount it the blowing my turbo up lol. As im sure a odd rag will be done !
Offline mcgee9t2
« Reply #9 on: 21 May 2014, 16:04 »
well then, you wanting to rag it will get you focused on buying the fmic and get it bought quicker :D
