Author Topic: Scratch removal  (Read 1738 times)
Offline Fabio Bignose
Scratch removal
« on: 19 May 2014, 11:26 »
Hi all,
I need to remove some light scratches from the clearcoat (3 year old daughter, long story!!)
Anyway, I have AG SRP which has helped but they can still be seen in direct light etc..
What is the next step up in abrasiveness?
I only need and want something a little more abrasive so would scratchx or AG paint restorer be recommended? Or any other?
Cheers!
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline monkeyhanger
Re: Scratch removal
« Reply #1 on: 19 May 2014, 11:53 »
I got a set of 3 scratch removal pens from Costco the other day. The lacquer they give out does soak into and fill the scratch, but still rests above the surface of the surrounding paint. I have ordered a few 3M sheets of 4000grit/P9000/3 micron to rub down for polishing in. Ended up being about £6.50 for 3 sheets delivered.
Offline JoeGTI
Re: Scratch removal
« Reply #2 on: 19 May 2014, 12:15 »
If you can feel the scratch with your fingernail then ScratchX or the likes will be useless. I've found it of fairly limited use anyway on VW paint / lacquer, obviously just not abrasive enough. If you can't feel the scratch with your nail then you might have some joy. I had a particularly bad bird-crap mark on my roof last summer and nothing by hand would shift it. Eventually got a pro-detailer to have a go with a machine and that fixed it.
