Author Topic: what size spacers + spigot rings do i need?  (Read 1702 times)
Offline TEST100
« on: 18 May 2014, 20:32 »
Ive got lenso bsx 16 x 7.5j   5x100   et 38/40 + et 20/25 on a golf mk3 gti 8v.need to know what size spacers i should run n do i need spigot rings...if so what size.
Offline tweed
Re: what size spacers + spigot rings do i need?
« Reply #1 on: 18 May 2014, 20:49 »
Depends what car but you'll want 15mm spacer on front. Rear will be fine.
If they are 5x100 ill doubt you will need a spigot ring.
What is the wheel bore?
New or used?
If used what car did they come off?
When making a thread give as much info as possible. We are not mind readers.
Offline tweed
« Reply #2 on: 18 May 2014, 20:50 »
I meant depends what brakes, but 15mm will be fine.
