Author Topic: dash  (Read 3636 times)
Offline danmusic24
dash
« on: 13 May 2014, 18:13 »
Do you need to remove steering wheel to take dash board out?
Offline boneybradley
  • Back in a Mk3...
Re: dash
« Reply #1 on: 13 May 2014, 19:02 »
I did and it's an easy job to remove the wheel (I don't think you have the space to remove the dash without? I always planned on taking the wheel off so never found out myself)
Offline danmusic24
Re: dash
« Reply #2 on: 13 May 2014, 19:05 »
Air bag puts me off!
Or is it a simple job to remove airbag and wheel?
  • Back in a Mk3...
Re: dash
« Reply #3 on: 13 May 2014, 19:11 »
It is simple, just ensure you disconnect the battery a good 30 minute before removing the bag. My bag just unclipped (there's 2 tabs on the rear of the wheel that need depressing) and the bag comes out. just be-careful with the wires that simply unplug and then it's same as removing a normal wheel
Offline Screech16v
  • MK3 20vt AGU
Re: dash
« Reply #4 on: 13 May 2014, 19:29 »
Its held on with two 5mm allen bolts from the rear  :smiley:
  • Back in a Mk3...
Re: dash
« Reply #5 on: 13 May 2014, 19:53 »
your right (my vr had a polo wheel fitted that has tabs not bolts)
Offline danmusic24
Re: dash
« Reply #6 on: 13 May 2014, 21:22 »
Nice one! Cheers  :wink:
Offline VR6_Wherry
Re: dash
« Reply #7 on: 14 May 2014, 09:05 »
You don't actually need to take the wheel off. I never did when I swapped out my interior but fcuk me was it a lot harder! :grin:
Offline danmusic24
Re: dash
« Reply #8 on: 14 May 2014, 18:30 »
So with wheel off is it a straight forward job removing dash?
Offline VR6_Wherry
Re: dash
« Reply #9 on: 15 May 2014, 10:43 »
Yeah, I believe there is two 8mm or 10mm bolts behind the scuttle panel too? if I remember correctly..
