Author Topic: Leaky headlight jet  (Read 1044 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Leaky headlight jet
« on: 12 May 2014, 21:18 »
I was missing my drivers side headlight jet so the screenwash would flow straight out so i decided to try and fix it.
Recently fitted a brand new jet and it worked fine only I just noticed that the screenwash is now leaking straight out the holes in the jet which spray the headlight
I can pull the whole piston out and see that there is no leak anywhere but out the very top literally if i pull it out its leaking in my hand outside the bumper and no where else
Guessing it might be A valve thats not closing properly could this be part of the pump ? Wish i didnt had the buggers seems when i take out the fuse( to disable them ) i loose power for windscreen jets as well unless that pump is on the way out causing the leak
also notice alot of water coming through the center grill and down the passenger wing to the bottom of the bumper
« Last Edit: 12 May 2014, 22:39 by 1.4golf_Chris »
