Author Topic: Auto vr gearbox broken :( replace or convert?  (Read 4703 times)
Offline jnufcuk
Got the news I was dreading my vr6 auto gearbox is broken. Driving in 2nd gear, slipping in 3rd, not going into reverse straight away.
Few options ;
1) find another auto vr gearbox?
2) get it reconditioned ?
3) what I've wanted to do for ages and convert to manual?
How much to convert to manual? Do I just need to find a manual vr breaking?? Get the right bits then get new clutch & flywheel ?
In the long run in thinking convert as if get more when I come to sell it plus always have the option of turboing it ;)
Thanks guys and gals
VW BUSH
Re: Auto vr gearbox broken :( replace or convert?
« Reply #1 on: 07 May 2014, 23:01 »
Easiest is to get another auto box, then its done in a couple of hours for under £150.
Manual conversion:
Box
fly
mounting brackets, mounts?
Shifter mechanism and trim
Pedal box/pedals and fittings
Radiator/box cooling delete
Relays/fuse box work
ECU? (imob/keys etc)
Probably missed a few things or got some wrong :grin:
Donor car could be had for as little as £150 so its not a major cost if you are careful its mainly time and space :smiley:
Offline tweed
« Reply #2 on: 08 May 2014, 19:16 »
Manual conversion is well worth it!
Offline leigh_harty
  • Audi AGU
« Reply #3 on: 09 May 2014, 21:19 »
Time and parts though? fix and sell, buy a manual  :whistle:
Dont lose your dinosaur!
Offline jnufcuk
« Reply #4 on: 09 May 2014, 22:05 »
Selling her now. If she doesn't sell I'll be stripping her which could be fun on a drive :/
VW BUSH
« Reply #5 on: 09 May 2014, 22:11 »
Funny how its cheaper to just buy a another Mk3 than fix em these days :grin:
Offline jnufcuk
« Reply #6 on: 10 May 2014, 09:04 »
Which is why it just isn't worth fixing her :(
« Reply #7 on: 10 May 2014, 10:02 »
Easier to stick with auto, manual conversion is a ballache unless you can get a donor car.
Offline leigh_harty
  • Audi AGU
« Reply #8 on: 10 May 2014, 10:51 »
Did mine on the road  :grin: took everything I wanted then called mr scrap man
Offline Jasikasisback
« Reply #9 on: 10 May 2014, 22:18 »
try topping up gearbox fluid first if no faulr codes and changing filter...may work...but expensive to try..../)
