Golf mk4
Wazzzer
Spring swop
Topic: Spring swop (Read 1341 times)
paultownsend
Spring swop
06 May 2014, 22:34 »
Quick easy question. Have a new set of Sachs OE springs for my GTI.
Can you change the front springs, with compressors, without taking out the struts.
I don't have the tool, and don't want to mess with the geometry.
scarr89
Mk4 Golf, DERV FTW!
Re: Spring swop
06 May 2014, 22:50 »
Lol. I would love to see someone try!
The springs fit over the strut. Unless maybe you unwind the spring around the strut
paultownsend
Re: Spring swop
07 May 2014, 08:20 »
I was thinking if i had an assistant compress the piston, and i had the spring already compressed?
gm8
Re: Spring swop
07 May 2014, 11:08 »
there is just not enough room man, even if you managed to get spring on you would still need to try get the top mount on too. Even without the proper 'spreader' tool to remove the strut, a big chisel and hammer will substitute.
gm8
Re: Spring swop
07 May 2014, 11:12 »
You wont mess with geometry if you dont remove the balljoint from the wishbone, But this will make your job harder ( but possible )
just mark the position of the ball joint bolts with tipex/touch up paint
mcgee9t2
Re: Spring swop
07 May 2014, 12:36 »
just use a few old hex keys to spread the strut mount if you cant get it out, however iv never had any trouble getting the struts in or out. few bangs with a hammer and a bit of elbow grease and out they pop
davidgtrr34
Here all the time
Re: Spring swop
Reply #6 on:
10 May 2014, 21:24 »
Yes you can because I did it.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Wayne
Sir Postalot
Re: Spring swop
Reply #7 on:
11 May 2014, 00:00 »
Not a chance, better to remove the strut and compress the spring, it it under massive tension.
Golf mk4
Wazzzer
Spring swop
