Author Topic: N80 Valve  (Read 1007 times)
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
N80 Valve
« on: 06 May 2014, 19:54 »
Hi,
Could a faulty N80 valve on the carbon canister cause a smell of fuel vapor at idle (after a drive).
I used to hear the valve ticking away, but I never hear it anymore and I suspect its not opening or closing. Is the valve likely to be the problem? Or could it be a split pipe causing a vacuum loss? I assumed as the ECU controlled the valve that it would open and close with no need for vacuum.
Thanks!
EDIT: Is the valve on top of the carbon canister actually the n80?
« Last Edit: 06 May 2014, 19:56 by MoshiMoshi »
I thought Volkswagens were supposed to be reliable?
Offline Dalo Harkin
Re: N80 Valve
« Reply #1 on: 07 May 2014, 08:25 »
to rule out all possibilities - delete it  :wink:
