Author Topic: rough idle  (Read 2109 times)
Offline leedsbora
rough idle
« on: 05 May 2014, 20:45 »
Hi im new to the vag scene and have a bora 1.6 8v (getting changed soon). IM having a bit of a nightmare trying to find a solution to a rough idle ive got, ive changed the maf sensor, cleaned the throttle body, changed plugs, ht leads and coil pack but its still got a rough idle. Anybody any tips or things to try cause mot due in June and with a rough idle it might affect emissions test. Any help appreciated
Offline viperjsy
Re: rough idle
« Reply #1 on: 18 May 2014, 16:18 »
is the throttle body cable or electric or try injector cleaner like slic 50
« Last Edit: 18 May 2014, 16:21 by viperjsy »
Offline itavaltalainen
Re: rough idle
« Reply #2 on: 18 May 2014, 18:43 »
what does the fault code memory say? or did you just change all these things on a whimp?
Offline leedsbora
Re: rough idle
« Reply #3 on: 21 May 2014, 20:09 »
There's no fault code, the throttle is a cable, ive sprayed the throttle body with cleaner its not as bad but still does it now and again. Would a hole in the backbox cause this to affect the o2 sensor?
