Author Topic: 00849 code  (Read 20043 times)
Offline viperjsy
00849 code
« on: 05 May 2014, 12:46 »
hi I am getting 00849 dtc what is it an is it a easy fix
Offline lee1989
Re: 00849 code
« Reply #1 on: 05 May 2014, 17:53 »
00849 - S-Contact at Ignition/Starter Switch (D)
00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition
Possible Causes
Terminal 15 OK, but Terminal S not OK
Fuse(s) faulty
Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
Possible Solutions
Check Terminal S
Check Fuse(s)
Check/Repair Wiring/Connector(s) from/to Ignition/Starter Switch (D)
Check/Replace Ignition/Starter Switch (D)
not sure if this is any help to you mate  :smiley:
Offline viperjsy
Re: 00849 code
« Reply #2 on: 05 May 2014, 22:19 »
I have no clue what to do or where to look
Offline viperjsy
Re: 00849 code
« Reply #3 on: 10 May 2014, 16:19 »
hi where will this be
a if possibal I pic please
« Last Edit: 10 May 2014, 16:22 by viperjsy »
Offline viperjsy
Re: 00849 code
« Reply #4 on: 10 May 2014, 18:56 »
I found where it is and there is no damage there
Offline topher
  • Administrator
  • fully functioning
Re: 00849 code
« Reply #5 on: 10 May 2014, 19:51 »
assuming all your fuses are good you may as well try changing the switch. you won't always find visible damage and its not uncommon for them to fail, I've had to change a few on various vws.
Offline viperjsy
Re: 00849 code
« Reply #6 on: 11 May 2014, 00:44 »
what is the part I need to get
Offline viperjsy
Re: 00849 code
« Reply #8 on: 13 May 2014, 14:03 »
all sorted
Offline Rhyso
Re: 00849 code
« Reply #9 on: 13 May 2014, 22:30 »
Care to share?
Might help others in the future if you post the solution  :wink:
