Author Topic: Drammatic rise in MPG  (Read 11834 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 05 May 2014, 12:09 »
After installing the DSD IC kit and pipe work I have noticed a very tidy increase in my MPG on motorway runs. The other day I almost touched 60 (59.6) on a 150ish mile trip. Astounded. I have never hit that before, usually at like 54/55.
So...could the IC be the reason why? Cooler inlet temps etc? How would this affect MPG?  :nerd:
Offline Rhyso
Re: Drammatic rise in MPG
« Reply #1 on: 05 May 2014, 12:15 »
Lack of boost leaks will be helping; turbo not working as hard etc
Dont forget the rise in ambient temperature too  :whistle:
Offline scarr89
« Reply #2 on: 05 May 2014, 12:34 »
Don't say the RISE in temperature has helped? I thought cold air was better for MPG!?  :undecided:
Offline Rhyso
« Reply #3 on: 05 May 2014, 14:00 »
You ever noticed how it drops during the winter??
Dont forget that diesels are horribly inefficient when they are cold  :tongue:
Cold air is better for POWER; why did you fit a larger intercooler?? To keep temps down and to reduce heatsoak   :nerd:
You got the 150?? Standard intercooler is surprisingly efficient  :lipsrsealed:
« Last Edit: 05 May 2014, 14:32 by Rhyso »
Offline scarr89
« Reply #4 on: 05 May 2014, 14:08 »
Yeaaa. Forgot about that tbh. I got power mixed up with MPG. Oh well...I'm getting really good results at the mo!
I replaed it with the S3 IC as my old one kaput. I had to self tap the pipes into the plastic end of the IC. I replaced the whole lot, no more issues...EVER. Hopefully  :smiley:
Offline Adam
« Reply #5 on: 17 May 2014, 09:31 »
Diesels like warm air for efficiency.
Down Hill From Here.
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 20 May 2014, 11:49 »
I've started seeing the computer read 60mpg on my 37 mile drive home a few times in the last 2 weeks. Driving to work is always less at around 52-53mpg. All on the computer mind.
The drive to work is always less probably because I'm overtaking and often late :D
I regularly see 600 miles from a tank. 150PD with R-Tech stage 1 remap to 185bhp and 320ft/lb of torques.
Mk4 Golf 150PD
