Author Topic: Annoying rattle  (Read 2766 times)
Offline falconmick
  • Golf MK7 R
Annoying rattle
« on: 04 May 2014, 21:21 »
Got annoying :angry: rattle that sounds as though it is the plastic panel inside of tailgate. Does anyone know how to remove this panel, there are 2 torx screws in the recess to pull tailgate down and also 2 more under the pull down flap, it's these 2 I am concerned about. Do they secure anything behind the panel, or are they there just to secure it? Don't want to take them out and anything behind fall off.
Offline monkeyhanger
Re: Annoying rattle
« Reply #1 on: 04 May 2014, 21:59 »
Use the car's warranty to get it sorted.
A common rattle on the Scirocco was the bump stops. Check both stick out the same number of notches. If not, stick a small (was it a 1.5mm/2mm?) allen key through the centre of the shorter bump stop, slacken it off and pull the bump stop out until it has the same number of notches as the other side and tighten allen screw again.
Offline falconmick
  • Golf MK7 R
Re: Annoying rattle
« Reply #2 on: 04 May 2014, 22:08 »
My previous experience of dealers & rattles is not good, took my MK6 back 4 times for same rattle and they still couldn't find it, hence I prefer to try myself.
Offline TheCarMadDad
Re: Annoying rattle
« Reply #3 on: 04 May 2014, 22:33 »
Haven't VW issued an advisory to the dealers regarding a rattle in the boot? Sure I read it on here somewhere
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline falconmick
  • Golf MK7 R
Re: Annoying rattle
« Reply #4 on: 04 May 2014, 22:46 »
Have searched site and cannot find anything related?
Offline dippy_x
Re: Annoying rattle
« Reply #5 on: 05 May 2014, 05:47 »
I think your looking for this boot rattle tpi thread.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
