Author Topic: 16v isv wiring  (Read 1797 times)
Offline Munrohuna
16v isv wiring
« on: 04 May 2014, 11:39 »
My isv has stopped working causing my car to stall and not idle as it should. I have cleaned the isv but have no power going to it.
From what I'm led to believe the black/white wire should have 12v going to it when the ignition is on which mine does not have.
I have checked the fuses which are ok so I suspect a break in the wire. Also am I right in thinking it is not the isv controller as the white wire goes to it and the black/white wire comes straight from the fuse box?
Any help much appreciated.
Offline Sgt_Lemon
  • 8v owners club
Re: 16v isv wiring
« Reply #1 on: 06 May 2014, 17:23 »
The back of the Haynes manual has a wiring diagram for these systems. I would find out where I've other ends of the wires are meant to go then do a circuit test on them to see if there is any break with a particular wire.
Offline Munrohuna
Re: 16v isv wiring
« Reply #2 on: 07 May 2014, 14:26 »
Thanks, that's what I plan to do this wknd. I have also got my hands on a spare isv control module so will rule this out as being faulty at the same time.
Offline Sgt_Lemon
  • 8v owners club
Re: 16v isv wiring
« Reply #3 on: 07 May 2014, 18:56 »
For electrical or wiring related stuff your best off also posting on clubgti forum. Rubjonny resides there now and he is basically a mk2 robot. He can whisper to the wires and locate their source.
