Author Topic: Squeaky electric windows  (Read 3817 times)
Offline Pld118
« on: 04 May 2014, 08:37 »
Hi, the car (a 3 door) has recently had the driver's door alignment worked on to try and cure intrusive wind noise when driving.  Not sure if it's coincidence but the driver's door electric window now squeaks/ rubs loudly when in use.  More so when it is on the downward motion but also on the upward motion.
Has anyone experienced this and if so, what's the cure for that please?
Thanks.
Offline charlie
Re: Squeaky electric windows
« Reply #1 on: 04 May 2014, 10:04 »
Give the rubbers around the window a clean
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Booth11
« Reply #2 on: 04 May 2014, 18:00 »
Probably the rubbers as charlie says, but failing that, it's worth blowing compressed air down the window channel just in case anything is lodged.  The aerosol type (with straw attachment) used for computers works ok.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Pld118
« Reply #3 on: 05 May 2014, 07:28 »
Thanks, for the blowing of air advice.
I spent ages cleaning the window rubbers on both doors yesterday, first with WD40 and finally with silicone gel.  It seemed to have made no difference at all, other than to ensure the windows were caked in greasy film.
It is strange that I've only really noticed this issue since the car had a second visit to the dealership for the door alignment to be corrected to try and cure the door wind intrusion.
Anyway, the cleaning and silicone cleaner on the seals does indeed seem to have worked because got in the car this morning and.... Both windows up and down time and again with no squeaks! The WD and silicone must have been soaking in overnight... Touch wood.
Thanks for what seems to have been a top tip  :smiley:
« Last Edit: 05 May 2014, 08:58 by Pld118 »
Offline Pld118
« Reply #4 on: 14 June 2014, 09:00 »
New window regulators fitted to both front windows which I'm told is the fix for this.
Offline Booth11
« Reply #5 on: 14 June 2014, 18:53 »
Glad to hear the issues are being sorted  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Pld118
« Reply #6 on: 27 June 2014, 08:38 »
VW confirmed that to diagnose the fault in this case they had to remove the door cards/ trims and on both doors (3 door), they found that both window regulators were twisted.  Both were replaced and are now warrantied for 2 years and importantly... seem quiet!  Schhhh...
