Author Topic: figure out oil problem  (Read 1332 times)
Offline jasonpi
« on: 05 September 2005, 13:44 »
ok been having probbs with the motor(non stop) was getting oil in and all over air box cleaned out hoses and still there!
so i took rocker breather hose off while engine was running took it of airbox end and to my surprise thats where the oil was coming from and also really hot thick smoke whih if its going into airbox cant be good...any ideas
Judderi
Re: figure out oil problem
« Reply #1 on: 05 September 2005, 14:21 »
Sounds like you have over filled your oil. If you have this is exactly what will happen.
Offline jasonpi
« Reply #2 on: 05 September 2005, 16:36 »
i havent no!!
 since ive got it ive regularly had to top up within limits had this problem when i got itand oil on the gearbox end aswell..
was thinking of stripping it down and rebuilding it new pistons skim the head etc etc just in two minds. also been topld the stem seals will need replacing aswell done 115,000 miles that i know of so maybe its time to do it
Offline sellers
  • Daz Works in Health and Beauty
« Reply #3 on: 05 September 2005, 18:32 »
i have that problem on roundabouts :grin:
oil goes to oneside and out the breather loadsa smoke, hasnt done it in a while
Can't think of a funy or whitty comment
Judderi
« Reply #4 on: 06 September 2005, 09:05 »
Looking at the post above it could be related to the baffles in the sump. If they are broken oil will swish around all over the place.
Offline jasonpi
« Reply #5 on: 06 September 2005, 18:48 »
would that be part of the sump guard itself if so would a new one do the trick
