Author Topic: Drivers side door won't lock! HELP  (Read 1574 times)
Offline Anderson9
« on: 01 May 2014, 10:49 »
My drivers side door doesn't lock when all the other doors lock when pressing the key fob then every now and then the drivers side will lock. It locks fine when I manually lock it with the key. ANybody got any ideas?
I've only had my GTi for 2 days and was working fine when I bought it, how many times do I press the lock the button ? Thanks in advance.
Offline bacillus
Re: Drivers side door won't lock! HELP
« Reply #1 on: 01 May 2014, 16:54 »
I would get a vcds scan as your door lock module could be failing.
Without traction power is nothing!
Offline th3_f15t
« Reply #2 on: 06 May 2014, 12:38 »
I have the reverse of this issue, where my drivers door won't unlock but locks fine. My guess too is that the locking module is a bit faulty. As long as you can lock it with the key it should be alright for now.
Moving over to Flickr, sorry for the broken picture links!
