Author Topic: Wheel Bearings  (Read 1678 times)
Offline WadGTI
  • Golf GTI'er
Wheel Bearings
« on: 01 May 2014, 09:01 »
Hi Folks,
Looking for some advice here. Over the past 24 hours with the heavy rain, my front drivers wheel started making horrible "rubber twisting, metal to metal and squeeling noises" as soon as I turn left/right at low speeds.
After jacking the car up, the wheel has serious play on the bearing. What is annoying is that I replaced this bearing back last June. I got a mate who is a time served mechanic to do it (as he has done some before for me without any issues). The bearingss are always instered via the press.
My question is, is there any recommendations between SNR or Orbis bearing from ECP. I would go to GSF and get an OEM Fag, but I need to get this fixed asap tomorrow. NO GSF close to me. Im sure I used a SNR bearing before.
Also I am thinking that a worn drive flange could cut the life of the bearing fast? Never replaced a drive flange before?
Any advice guys.
Offline WadGTI
  • Golf GTI'er
Re: Wheel Bearings
« Reply #1 on: 01 May 2014, 10:00 »
I will add the bearing has only covered 10009 miles...as per my oddo.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Bearings
« Reply #2 on: 01 May 2014, 11:35 »
Yes if the wheel flange is worn it will kill a bearing fairly quickly. It's the same process to replace them, just press a new one in to the bearing
Offline WadGTI
  • Golf GTI'er
Re: Wheel Bearings
« Reply #3 on: 01 May 2014, 12:36 »
Sorry Wazzer for being silly...but am I looking at replacing the hub?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline Dizzie
  • Make friends with your fast
Re: Wheel Bearings
« Reply #5 on: 02 May 2014, 11:57 »
you can't replace that without doing a bearing at the same time. once the old one is pressed out half the bearing will be attached to it writing off the bearing.
Mk4 Golf 150PD
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Bearings
« Reply #6 on: 02 May 2014, 14:34 »
I know that, he said he is replacing the bearing anyway if you read the original post properly
Offline Dizzie
Re: Wheel Bearings
« Reply #7 on: 02 May 2014, 15:32 »
my apologies. that'll teach me to reading the post backwards and skimming
Mk4 Golf 150PD
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Bearings
« Reply #8 on: 02 May 2014, 17:39 »
That sounded quite harsh sorry mate
