Golf mk4
Wazzzer
AGU ECU swap.
Topic: AGU ECU swap. (Read 4667 times)
markymarkg
AGU ECU swap.
30 April 2014, 17:55 »
Got my hands on a supposed mapped ECU for my AGU 1.8t.
I know it will plug in fine but what would i need to do so the engine would run with this unit.
Cheers.
barrym381
Forum addict
Re: AGU ECU swap.
30 April 2014, 18:50 »
get the immobiliser turned off on the ecu or have your key coded to it
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: AGU ECU swap.
30 April 2014, 20:31 »
do you know the part numbers of either?
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
topher
Administrator
Serious forum addict
fully functioning
Re: AGU ECU swap.
30 April 2014, 20:38 »
you can do it with vagcom with those ecus. no need for any login codes its a simple adaption takes 2 minutes.
Chris.
Re: AGU ECU swap.
20 May 2014, 01:14 »
as above. info is on ross techs site under IMMO 2 instructions.
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
tonysgti
Here all the time
Re: AGU ECU swap.
20 May 2014, 09:25 »
Where abouts are u?
markymarkg
Re: AGU ECU swap.
Reply #6 on:
08 February 2015, 13:26 »
Glossop, just outside manchester.
Perryd84
GTI forum regular
MK4 Golf 1.8T 20V GTI
Re: AGU ECU swap.
Reply #7 on:
09 February 2015, 10:25 »
I had one of those. It's literally just plug and play as long as you got one with the immobiliser turned off.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
benmanc
Here all the time
Re: AGU ECU swap.
Reply #8 on:
09 February 2015, 20:38 »
Doesnt that leave the car far less secure with it turned off?
barrym381
Forum addict
Re: AGU ECU swap.
Reply #9 on:
09 February 2015, 20:48 »
Quote from: benmanc on 09 February 2015, 20:38
saves them breaking in to your house for the keys
as that's what happens these days
Golf mk4
Wazzzer
AGU ECU swap.
