Author Topic: Obd port  (Read 1908 times)
Offline Terryturbo
  • Asbo mk4 1.8T
Obd port
« on: 26 April 2014, 16:11 »
I have a problem with my obd port it won't read any scanners it comes back not found and I've noticed when I switch my ignition on there is no management light I've checked all my fuses the port powers up the scanner just won't read it any ideas thanks
Offline dom
  • Back in a Mk4
Re: Obd port
« Reply #1 on: 26 April 2014, 17:11 »
Do you have an after market head unit?
Offline MoMartin
Re: Obd port
« Reply #2 on: 26 April 2014, 17:14 »
I think I've read somewhere that the engine management light is disabled / will only come in if it's a severe breakage.
And what kind of old scanner are you trying? Because the older agu engines have an ecu that don't connect to some obd scanners (such as the bluetooth obd2 scanner)
Offline dom
  • Back in a Mk4
Re: Obd port
« Reply #3 on: 26 April 2014, 17:22 »
1. All AGUs are readable by OBD port.
2. AGUs don't have an engine management light - maybe what you're thinking of?
My money is on the K-line in the wiring harness being used by an after-market head unit, therefore stopping the reading from communicating with the ecu.
Offline Terryturbo
  • Asbo mk4 1.8T
Re: Obd port
« Reply #4 on: 26 April 2014, 17:28 »
Thanks, so can't I just disconnect the head unit then
Offline Bandit127
Re: Obd port
« Reply #5 on: 26 April 2014, 18:22 »
Have a good read through this:
http://www.ross-tech.com/vag-com/aftermarket-radio.html
It should answer your questions.
Offline dom
  • Back in a Mk4
Re: Obd port
« Reply #6 on: 26 April 2014, 18:36 »
No, you need to pull the pin from the wiring harness that is connected to the k-line.
Offline MoMartin
Re: Obd port
« Reply #7 on: 26 April 2014, 19:29 »
1. Yeah, i know, but i meant that some tools wont work, like the bluetooth obd2 scanner. - well atleast it doesn't work on mine haha
2. and yeah, i knew i heard something along those lines.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Obd port
« Reply #8 on: 26 April 2014, 20:55 »
It's to do with the type of OBD used on AGUs; it's the early type so no it's not compatible with bluetooth units
Offline viperjsy
