Author Topic: Clutch peddle  (Read 1724 times)
Offline Aggrofish
Clutch peddle
« on: 24 April 2014, 18:16 »
Hi guys,
I was driving along the other day and when I changed gear I heard and felt a crunch and the peddle stayed down.  I couple of plastic bits fell to the mat and I was stuck in third!
Managed to pull over and raise the peddle and somehow got it in to gear again and drove home.  I was only about half a mile away luckily.
What has gone wrong here and what do I need to replace/fix?  Can I do it myself or should the young lad next door who works for Kwik Fit be able to sort it for me?
Thanks,
Ross
Offline gm8
Re: Clutch peddle
« Reply #1 on: 24 April 2014, 18:40 »
http://uk-mkivs.net/topic/2672-clutch-pedal-swap-out-repair/
lots of us have been there. Few quid and some swearing required
Offline falconmick
  • Golf MK7 R
Re: Clutch peddle
« Reply #2 on: 24 April 2014, 19:11 »
What is a 'peddle'?
Offline topher
  • Administrator
  • fully functioning
Re: Clutch peddle
« Reply #3 on: 24 April 2014, 19:33 »
What is a 'peddle'?
don't be pedalntic :tongue:
Offline vwprime
Re: Clutch peddle
« Reply #4 on: 24 April 2014, 20:15 »
Had the same thing happen but the pedal broke completely.
Was Abel to fix it myself (with a new pedal) but like what gm8 said you will be swearing a but and complaining if back ake after :-). I used a lot go cable ties to hold the spring in the compressed state. Something which I strongly sagest doing before taking it to bits :-).
TRANSFORM, & ROLL OUT!
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: Clutch peddle
« Reply #5 on: 24 April 2014, 22:55 »
I was lazy and got the garage to fix it. Only cost me £70 with the new pedal and clips. Think I might be close to getting a regulars discount.
I thought Volkswagens were supposed to be reliable?
Offline vwprime
Re: Clutch peddle
« Reply #6 on: 24 April 2014, 23:36 »
Probably best as its not the most relaxing of things to fix.
Offline Aggrofish
Re: Clutch peddle
« Reply #7 on: 18 May 2014, 16:40 »
Sorry I meant pedal of course!
Anyway I bought a new pedal on ebay for £40 delivered and my neighbour who is a bit handy fitted it for me!  Awesomes.  A garage quoted me a few hundred quid!
