Author Topic: Temp and fuel gauge problems  (Read 1798 times)
Offline jamiesgolf
« on: 23 April 2014, 10:49 »
Hi, sorry for all the posts, having a few problems at the moment!
My fuel gauge and temperature gauge have started playing up. The fuel gauge shows about half a tank of fuel (which is probably about right) but then will go up and down a lot, and sometimes even drop to empty so the fuel light comes on, before returning to 1/2.
The temperature gauge shows around 70 degrees even after running for half an hour, and fluctuates up and down slightly while driving.
Not sure if they are related or not, any ideas what might be causing it?
Thanks in advance
Offline dom
  • Back in a Mk4
Re: Temp and fuel gauge problems
« Reply #1 on: 23 April 2014, 16:10 »
The fuel gauge is probably a faulty sender in the tank.
Temperature will either be the thermostat or coolant temp sensor, does it ever get up to 90? In traffic or on idle?
Offline jamiesgolf
« Reply #2 on: 23 April 2014, 17:14 »
cheers for your reply. It does get up to 90 sometimes yeah, sometimes it will sit at 90 as it should, but other times it won't hit 90 at all
Offline dom
  • Back in a Mk4
« Reply #3 on: 23 April 2014, 20:14 »
My money is on the thermostat then.
Offline jamiesgolf
« Reply #4 on: 23 April 2014, 21:37 »
Okay cheers. As for the fuel gauge problem, stupid question, but can I just change the sender or do you have to change the pump as well?
Thanks for your gelp
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #5 on: 24 April 2014, 03:48 »
Just change the sender, videos all over YouTube
http://youtu.be/TciQ9RlAzH0
And I would say thermostat for the other problem
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline jamiesgolf
« Reply #6 on: 24 April 2014, 09:37 »
Ok cheers, any idea whether the sender from a 1.6 will be the same? I live in guernsey so access to parts isn't easy!
Offline jamiesgolf
« Reply #7 on: 24 April 2014, 20:39 »
I changed the sender today, and I've still got the fuel gauge problem. When I had the sender out, I moved the float up and down slowly with the connector plugged in. The fuel gauge moved from empty to full as it should, but then I put it back in the tank and I still had the problem. At this point I swapped it for a replacement, but the problem still persists. Any ideas what else it might be?
Offline jamiesgolf
« Reply #8 on: 25 April 2014, 12:08 »
Also noticed that it happens when I go round a corner?
