Author Topic: Engine misfire  (Read 1666 times)
Offline jamiesgolf
Engine misfire
« on: 23 April 2014, 10:02 »
Hi guys, I have a 2.0l 8v gti which I got for £300 as it had a misfire on cylinder 4. I ran a diagnostics and it showed cylinder 4 misfire detected, and injector circuit open cylinder 4. I tried numerous fixes before giving up and taking it to a garage. They simply cleaned the injector, and changed the HT leads at a cost of £250!!!! On my drive home it was still misfiring and spluttering badly, so I opened up the engine bay and noticed the injector connector wasn't on properly so I put it on properly. I then took the car for a drive and it was no longer misfiring. I then cleared the fault codes and then went for another drive. Almost immediately the ecu picked up the misfire again even though I cannot hear nor feel it any more.
Before I took the car to the garage I assumed it had to be the injector or injector wiring harness that needed replacing but I thought id
Take it to a mechanics as they'd know for sure and I thought it'd be a cheapish fix.
Any ideas what's causing the misfire that is now unnoticeable?
Thanks for any help in advance!
Offline gm8
Re: Engine misfire
« Reply #1 on: 23 April 2014, 10:06 »
faulty coilpack ?
Offline jamiesgolf
Re: Engine misfire
« Reply #2 on: 23 April 2014, 10:22 »
Already changed it, and the maf sensor, and all spark plugs. None made a difference :-/ oh and another mechanic I gave it to changed the coolant temperature sensor which also made no difference
Thanks for your help
Offline mike1990
Re: Engine misfire
« Reply #3 on: 23 April 2014, 20:01 »
Get the car scanned for fault codes and compression test it
Offline james2
  • No scammers please.
Re: Engine misfire
« Reply #4 on: 23 April 2014, 20:31 »
£250 for not fixing it sucks.  :shocked:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline jamiesgolf
Re: Engine misfire
« Reply #5 on: 23 April 2014, 21:39 »
Yeah I've run a diagnostics and nothing new is showing up. Yeah it's really annoying, especially when you're a student! Charged me £10 to take it for a 'test drive' which they obviously didn't do as it was still
Misfiring!
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: Engine misfire
« Reply #6 on: 23 April 2014, 22:23 »
If they charged you for 'HT leads' I'd be suspicious. Your car doesn't have them to speak of, it has a coil pack wiring harness and coil packs that step the voltage up to generate the spark. I'd be taking it back and having words, easier said than done sometimes though!
I thought Volkswagens were supposed to be reliable?
Offline topher
  • Administrator
  • fully functioning
Re: Engine misfire
« Reply #7 on: 24 April 2014, 16:07 »
its a 2.0 they don't have individual pencil coils, just one coil pack and ht leads.
Offline MoshiMoshi
Re: Engine misfire
« Reply #8 on: 24 April 2014, 22:54 »
Ahh, should have noted the 2.0 in the post. Well, I'll be leaving now!  :grin:
