Author Topic: How does your starter motor sound?  (Read 1666 times)
Offline Pld118
« on: 23 April 2014, 09:09 »
Hi,
I'm convinced that on start up - although the car fires up crisp and clean each time the ignition key is turned only once - there is a very brief, right on the point of fire up/ start up, slight grinding or spinning noise that makes me query whether or not the starter motor/ fly wheel are on the way out.  The garage checked this for me last week and felt they were fine.
Is this a trait of these cars or do these symptoms sound nothing like your car on start up?
Please/ thanks.
Offline MustardGTI
Re: How does your starter motor sound?
« Reply #1 on: 23 April 2014, 12:43 »
Mine certain doesn't make any odd noises like that.
I'm guessing you've only just bought the car, if not did it make the noise previously?
Offline Booth11
« Reply #2 on: 23 April 2014, 12:47 »
Mine neither.  What year is the car?
Is it on all starts or just on cold start up?  Not to alarm you, but I take it you have read the timing chain tesioner thread at the top of this section.   The timing chain sound is more of a rattle.  In the first post of that thread there is a video sound clip of it so you can compare, hopefully to rule it out.  There have been various part revisions so it depends what year.
« Last Edit: 23 April 2014, 13:43 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline dereks
« Reply #3 on: 23 April 2014, 14:43 »
car's with timing chain's tend to make a slightly different noise on start up.
Offline Pld118
« Reply #4 on: 23 April 2014, 17:06 »
Thanks for the replies.
2010MY and owned car less than a month.  It's not the timing chain tensioner related noise (warranty covered if that goes wrong, fortunately).  This is a pure and simple starter noise.  The car is going in to the dealership again tomorrow and I'll get them to check it again.  It's not much of a noise but enough to make me think "is that the starter motor".  Hopefully I'm just being over cautious.
Offline fentshire
« Reply #5 on: 23 April 2014, 21:16 »
Have you got them to check the timing chain problem?
Offline Pld118
« Reply #6 on: 23 April 2014, 21:45 »
fentshire... Yes, I asked them to thoroughly check if it was starter motor or timing chain and they said all was well. I trust them as they fitted a new clutch without quibble when I highlighted a noisy gear selection issue.
Offline RocketRossUK
« Reply #7 on: 23 April 2014, 23:44 »
easy way to check if it the timing chain, get some to start it up, you pop the hood and listen for a 1-3 noise near the left hand side of the engine.
PS. they may changed the clutch, but timing chain is 15+ hours labor
