Author Topic: Dash warning to STOP! With the coolant temp symbol?  (Read 2530 times)
Offline Bfstrachan
Need some help. Was driving home tonight and the engine temperature gauge shot up to 130 and the dash had a STOP! Warning with the thermometer symbol. Anyone know what caused this. I drove the rest of the way home at 40 mph and the temp did drop, but as soon as I put my foot down the temp gauge started to creep up. I checked the coolant and there is no leak, the resevouris full. Didn't check the radiator fan though. Would the fan not kicking in cause such a rapid climb in temp?
Any help will be much appreciated.
Offline davidgtrr34
Re: Dash warning to STOP! With the coolant temp symbol?
« Reply #1 on: 22 April 2014, 19:28 »
If it was the fan then the temp would go down when u drive and go up when u stop. I wouldmcheck your thermostat it sounds like it is sticking closed
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline barrym381
« Reply #2 on: 22 April 2014, 19:31 »
sounds like your water pump is broke  :sad:
Offline dom
  • Back in a Mk4
« Reply #3 on: 22 April 2014, 20:04 »
Agreed.
Offline Bfstrachan
« Reply #4 on: 22 April 2014, 21:39 »
Thanks guys, the thermostat was just changed a few weeks ago. Water pump! Is that an easy fix?
Offline barrym381
« Reply #5 on: 22 April 2014, 21:45 »
its easy if you know what your doing but while there your better doing the timing belt if its not been done in the last few years  :smiley:
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 23 April 2014, 10:57 »
100% water pump. The plastic prop is staying still while the shaft spins. Replace it with a metal version for no more problems.
You might as well do a cam belt while you replace it since the belt has to come off anyway when you swap the pump.
Mk4 Golf 150PD
Offline dom
  • Back in a Mk4
« Reply #7 on: 23 April 2014, 16:09 »
DO NOT replace it with a metal pump, the damage will be much more severe when it fails.
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #8 on: 24 April 2014, 03:42 »
Agree with Dom on that, it's plastic for a reason, when it fails you know about it
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline mcgee9t2
« Reply #9 on: 25 April 2014, 12:36 »
why not replace it with metal one??
the plastic goes brittle from being heated and cooled repeatidly for 12+ years. eventually it snaps/cracks and starts to spin on the shaft.
if you replace it with a metal one its not going to be as suseptable to heat and tougher and wownt crack.
its not asif the prop has hit off something and this has caused damage to one of the blades etc. just general wear and tear? or this is what it was when i replaced mine...? unless im missing something?
