Author Topic: maths nvq2 How do you work this out ?  (Read 11970 times)
Offline james2
  • No scammers please.
« on: 22 April 2014, 16:46 »
I could not work this one out ,can someone explain it please.  :laugh:
A guy has a roll of ribbon thats 25m long he cuts it into 90cm lengths to tie on a gift, how many rolls will he need for 500 gifts ?  :undecided:  i just guest 5  :rolleyes:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline tweed
Re: maths nvq2 How do you work this out ?
« Reply #1 on: 22 April 2014, 16:51 »
18
« Last Edit: 22 April 2014, 16:54 by tweed »
Offline hobbiniho
« Reply #2 on: 22 April 2014, 17:08 »
19 rolls
Offline james2
« Reply #3 on: 22 April 2014, 17:15 »
How do you work it out because you have to show how you got your answer ?
Offline tweed
« Reply #4 on: 22 April 2014, 17:15 »
No its 18  :grin:
Offline tweed
« Reply #5 on: 22 April 2014, 17:18 »
2500÷90 = 27.7777777778
27.7777777778×18 = 500
Offline hobbiniho
« Reply #6 on: 22 April 2014, 17:20 »
No its 18  :grin:
i disagree 25/0.9=27.777.... so thats 27 bits of ribbon that are 90cm per roll with a bit of wastage, 500/27=18.5185... so you need 19 rolls as if you only had 18 rolls there would be 14 presents without a bit of ribbon thats 90cm long
Offline tweed
« Reply #7 on: 22 April 2014, 17:27 »
No its 18  :grin:
Ok 19 rolls  :grin:
« Last Edit: 22 April 2014, 17:41 by tweed »
Offline dom
  • Back in a Mk4
« Reply #8 on: 22 April 2014, 17:27 »
Definitely 19 rolls, as hobbiniho says, you get 27 full lengths of ribbon from each roll. The 0.77 is useless and cannot be used as part of a 90cm length.
If you divide 500 gifts by 27 lengths of 90cm you get 18.5 rolls
Again, part rolls are no good. 18 rolls * 27 lengths =486 gifts therefore 19 rolls are needed to do the full 500 gifts.
Offline tweed
« Reply #9 on: 22 April 2014, 17:29 »
My bad 19 lol I put that at first then changed it
« Last Edit: 22 April 2014, 17:31 by tweed »
