Author Topic: MK2 20VT conversion...Help needed  (Read 1475 times)
Offline freddie86
« on: 22 April 2014, 14:11 »
Hi,
Im relatively new to this forum so apologies if i have posted in the wrong section, or theres a section already that recommends mechanics...
I have owned VWs all my life however first time im doing a conversion so require a gentle prod in the right direction.
Im wondering if someone can recommend me a garage or someone who has carried out this type of conversion before and knows what they are doing in the south Buckinghamshire region. Im a fan of R-Tech but they arent taking on the work as the management the car is running is Emerald. I also like JKM performance but they cant take on the work right now.
What I have:
MK2 1992 Big Bumper
1.8T AGU block and head
Emerald k6 ECU
ko4 turbo with 2.5" QPENG manifold and custom made powerflow exhaust
running bosch green top injectors, but will soon order genesis 550cc
FMIC
02J gearbox
... you get the gist
What I need done:
Its not a great deal of work to be honest, most of it is trivial.
Fuel filter needs changing
Something is restricting the turbo needs some troubleshooting my gut feel is its the actuator that may need attention
Need a new fuel pump, so someone to recommend then install it
A coolant leak needs attention
There are a few other bits and pieces that need doing. None of the work is major. Just need someone to finish it off so i can enjoy it this upcoming summer
Thanks
