Author Topic: DSG gearbox noises  (Read 2970 times)
Offline Prior7
DSG gearbox noises
« on: 19 April 2014, 22:24 »
Alright guys,
Got my mk6 GTI about 2 weeks and last week it started making a slight knocking noise when pulling away. As soon as it changes up to second or you are moving the noise stops. Was wondering if anybody had a clue what it is?
Something else it's started to do today is when I put it into drive it quickly switches between auto and manual as if it's confused as to what's being asked of it. It doesn't do it when I go from sport but only when I go from park, reverse or neutral. Again was hoping somebody would be able to enlighten me as to what could be happening?
Thanks for any replies in advance :)
Offline charlie
Re: DSG gearbox noises
« Reply #1 on: 19 April 2014, 22:30 »
My advice would be take it back to the garage and get them to sort when was the gearbox last serviced did you get it from a vw garage and did it come with warranty hope you get it sorted
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Mattyj
« Reply #2 on: 19 April 2014, 22:36 »
As above i heard these are very expensive when they go pop
Offline Prior7
« Reply #3 on: 19 April 2014, 22:59 »
The car was serviced by the garage I bought it from before I picked it up. I didn't get it from a VW garage but I'll have to take it back to where I bought it to see what they say
Offline Booth11
« Reply #4 on: 19 April 2014, 23:10 »
Doesn't sound right.
What do mean it switches between auto and manual?   By itself?  Are you using the paddles at all when in drive mode, as this will override drive and put it into manual.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Prior7
« Reply #5 on: 19 April 2014, 23:15 »
I select drive (auto) and it switches between drive manual and then back to drive auto by itself and then stays in auto. You can hear the engine change it's tone like it would when you select manual yourself. I used the panels before it happened but I rarely use them.
Offline Booth11
« Reply #6 on: 19 April 2014, 23:30 »
Weird.  I assume you aren't accidentally knocking the gear lever over to the left (manual) of drive when selecting.
I just wondered about the paddles because, as you probably know, if you shift with paddles in Drive, it goes into manual but if you then don't touch the paddles for a short time it reverts back to drive mode, or if you keep your finger held down on the + paddle it also puts it back into drive mode.  Just wondered if you may inadvertently have done this.
« Last Edit: 19 April 2014, 23:39 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline charlie
« Reply #7 on: 20 April 2014, 00:03 »
let us know how you get on
Offline Prior7
« Reply #8 on: 20 April 2014, 00:12 »
No I don't think I've been doing that, it just seems to be a little confused when I select drive which is quite strange. I'll see what the garage say and hopefully let yous know so yous know what it is. Thanks for the advice.
Offline Booth11
« Reply #9 on: 20 April 2014, 00:31 »
My previous mk5 gti dsg would very occasionally refuse to shift up in Drive (usually after being in manual).  It seemed to think it was still in manual.  I never bothered getting it checked as it only happened a few times and knocking the lever to M and then back to D sorted it.  Never happened on the mk6.
Hope the garage get it sorted for you.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
