Author Topic: Coolant loss  (Read 4278 times)
Offline mwad gti
Coolant loss
« on: 16 April 2014, 15:36 »
Anyone had coolant loss in their GTi ?
My coolant was half way between between Max and Min when it went in for it's first service in September with only 5500 miles or so on it. I asked the Stealers to check it, after a pressure test all was deemed OK.
Checked it again yesterday, car has now only got 7700 miles and the coolant was half way between between Max and Min again ! No leaks anywhere either.
Funnily enough, my Brother/Sister In Law have got the exact same problem starting on their MK5 GTi.
Any ideas ?  Anyone had this before ?
Thanks guys
Mark
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline Mattyj
Re: Coolant loss
« Reply #1 on: 16 April 2014, 15:43 »
Try taking the lid off with car not running as its a pressurized system it should rise a touch mine does anyway gtd but i've not heard of any coolant losses on the mk6.......yet
Offline Booth11
Re: Coolant loss
« Reply #2 on: 16 April 2014, 16:06 »
You say they checked it at the service, but did they actually top it up?  Was it at the max mark when you got it back?
I've had to top up my coolant once but has been ok since then.  I would just monitor it weekly and if it continues to drop get it checked out.
This might be worth a read.  Leaking water pump has been an issue on some mk6s.
http://www.golfgtiforum.co.uk/index.php?topic=243582.msg2240195#msg2240195
« Last Edit: 16 April 2014, 16:20 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline ab17790
Re: Coolant loss
« Reply #3 on: 16 April 2014, 20:45 »
Hi
Ive seen this on some Audi Models
Check the Auxilary Watery Pump :) it is located just below the manifold,if leaking you will see coolant marks running down onto the sump.
-Very similar to this
http://www.a5oc.com/forums/a5-general-q/22297-low-coolant.html
My Car-2016 Golf 1.0 TSI Match Edition BlueMotion 115PS,17inch Singapore Alloys,Tech Pack,Parking Pack,Rear Camera,Heated Steering Wheel,Winter Pack,90% Window Tints,Front & Rear Mud flaps,Headlight and Boot Protector
Dad-Golf MK7.5 R Estate Pearlescent Black,Reversing Camera
Mum- Golf MK7 GTI PP 5 Door-Manual,White,90% Tints,Rear Camera,Front and Rear Mudflapa,19 Inch Santiago Wheels
Audi Technician
Offline mwad gti
Re: Coolant loss
« Reply #4 on: 16 April 2014, 21:22 »
yes it was topped up at the service
It’s a keeper
Offline mwad gti
Re: Coolant loss
« Reply #5 on: 16 April 2014, 21:22 »
Hi
There are no leaks, also confirmed by the dealer
« Last Edit: 16 April 2014, 21:55 by mwad gti »
It’s a keeper
Offline Snooze
Re: Coolant loss
« Reply #6 on: 18 April 2014, 21:06 »
Sounds a bit odd. I've had to top mine up once, but it's remained steady since then.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline andygo
Re: Coolant loss
« Reply #7 on: 19 April 2014, 00:22 »
It might be leaking so slowly that nothing appears on the ground. Open the bonnet and look on the plastic undertray for signs of evaporated coolant.
Mine did this and I changed the water pump myself which was a bit of a mither, but saved me £400 or so at the stealers. New VW water pump was about £160.
If you are losing water you must have a leak somewhere.
Offline mwad gti
Re: Coolant loss
« Reply #8 on: 19 April 2014, 08:50 »
Good point.
Thanks guys
It’s a keeper
Offline Mattyj
Re: Coolant loss
« Reply #9 on: 19 April 2014, 19:08 »
Sorry to state the obvious but i guess you had to play with cambelt whilst doing this?
