Author Topic: Front spring size  (Read 2578 times)
Offline Splash
Front spring size
« on: 13 April 2014, 16:17 »
Hi all. I understand there are two different front spring sizes (tops) for Mk3 Golf GTIs. Is there an easy way to tell which mine is without dropping a strut, ie can you tell from chassis code or anything like that? The car's a 1994 M-plate 16v GTI. Cheers.
Offline tweed
Re: Front spring size
« Reply #1 on: 13 April 2014, 16:44 »
No all gti are the same. Gti are different from smaller models a vr6 will bd different too. But all gti springs are the same.
Offline snozan
« Reply #2 on: 13 April 2014, 16:56 »
Hmm, not when i changed. Mine had 3 colour dots "2 paint mark violet 1 paint marks yellow". Isn't it depending on what  accessories the car has?
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
Offline Foreveryoungaus16v
« Reply #3 on: 13 April 2014, 17:47 »
Listen to the Wheel Specialist
163 BHP (TSR POWER RUN)
Offline Splash
« Reply #4 on: 13 April 2014, 18:51 »
Thought there were different spring-top diameters dependent on year? Thought the change-over was year related - around 1994?
Offline snozan
« Reply #5 on: 13 April 2014, 19:23 »
correct, but then it depends on what things the car has, climatronic etc
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 13 April 2014, 20:10 »
There are 2 choices 80mm pigtails up to 04/95 (build month not reg month!) and then 65mm pigtails on the fronts.
you can use the late springs on earlies and just need new top spring plates and vice versa
Offline Splash
« Reply #7 on: 14 April 2014, 20:09 »
Are the later springs slightly shorter too? It's just that later cars always simple a bit more nose-down. Can I find build date info on ID plate? Thanks for your help.
  • Back in a Mk3...
« Reply #8 on: 14 April 2014, 20:51 »
Chassis number will tell which are fitted (feel free to pm me if you don't want it posted on the thread)
