Author Topic: early 2011 GTI golf or early 2012 gti golf  (Read 3280 times)
Offline Pld118
Re: early 2011 GTI golf or early 2012 gti golf
« Reply #10 on: 16 April 2014, 10:17 »
Not hijacking thread (hopefully) but can genuine front and rear LED main light units be bought as plug and play for the 3 Door 2010 MY please?
Thanks.
Offline dubber36
« Reply #11 on: 16 April 2014, 11:21 »
Thanks.
Rears are a straight swap and will work, but require coding to turn off the bulb out message on the dash.
If you currently have OEM xenons, then retro fitting later LED xenons is straight forward, just needing a little coding. Fitting xenons into cars with halogen lights is not so straight forward. You need a different BCM to control the main beam shutter as well as some additional coding.
Offline Pld118
« Reply #12 on: 16 April 2014, 13:50 »
Thanks. The fronts are halogen. Like the look of the car stock and as is, so probably not worth the trouble.
