Author Topic: Bora Xenon Look Headlights - Thoughts?  (Read 3114 times)
Offline Rhyso
Re: Bora Xenon Look Headlights - Thoughts?
« Reply #10 on: 20 April 2014, 19:25 »
Yes I know, but legalities Rhys! Need headlight washers and self levelling, I have neither.
Not to pass an MOT you dont.......
The MK4 has the ballasts built into the back of the lights anyway so thats one issue sorted
Offline Adam
« Reply #11 on: 21 April 2014, 09:48 »
There is no legalities.....
Down Hill From Here.
Offline dom
  • Back in a Mk4
« Reply #12 on: 21 April 2014, 18:31 »
You'll be fine with projector lenses Kirk, it's bellend who run HIDs in standard headlights that need shooting.
Offline Rhyso
« Reply #13 on: 21 April 2014, 18:45 »
Yeah i think he is confused.....OEM xenons are in the correct units and offer far better light output than any HID kit. The trick is to retain the OEM light output of 4300k. The higher the number the worse the light output
Offline dom
  • Back in a Mk4
« Reply #14 on: 21 April 2014, 19:15 »
Agreed, once you start going above 4300k it goes too blue.
Offline Shady Pioneer
  • graphic designer.
« Reply #15 on: 21 April 2014, 19:27 »
I was always under the assumption HIDs needed headlight washers and self levelling to pass MOT, I'm not looking at retrofitting aftermarket HIDs either, just wanted the Xenon look headlights from a Bora (the style).
Anyway, even if I did find some OEM Xenons, they are extremely expensive and are as rare as horse poop.
Offline Rhyso
« Reply #16 on: 21 April 2014, 19:43 »
Its a grey area.....
Technically they should be fitted but if they arent fitted then they cannot be tested and therefore failed for not working
Also as long as the beam pattern is level and correct then thats ok too
Mine has passed its last two MOT's this way at two different garaged
