Author Topic: what turbo is best  (Read 1749 times)
Offline adriangtiturbo
what turbo is best
« on: 10 April 2014, 13:35 »
can any one tell me what turbo is best to use off audii tt? been told its the 225 bhp and that it will bolt straight on my golf just need to get it remaped. any one no how true this is??????????
Offline benmanc
Re: what turbo is best
« Reply #1 on: 10 April 2014, 13:37 »
Its bullsh!t.
You need manifold, downpipe, supporting hardware. Once you have all that then its 'bolt on'?
then map
Tons of threads on it
« Reply #2 on: 10 April 2014, 13:40 »
cheers did think i was being told bolloxxxx.
Offline benmanc
« Reply #3 on: 10 April 2014, 14:15 »
It does fit on, but not a straight swap.
You have to swap other stuff to make it fit. Not just the turbo. Pretty much everything it connects to is different
Offline shaft69
« Reply #4 on: 10 April 2014, 20:56 »
buying k02-02x with oil/water pipes, injectors, manifold and map to run it expensive its rest of bits needed run it. i've got f23 on mine now, but add ons cost the money. running 42dd turbo pipe with 3" d/pipe and sports cat pretty expensive best if want k04 keep checking ebay full kits come up now and then someone else has had in mk4
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Dalo Harkin
« Reply #5 on: 11 April 2014, 12:23 »
I still think its a lot of extra money is it worth it from a Stage 2 K03s .....
Offline LittleReDuck
  • '98 180bhp MK3 1.8T and Loving It
« Reply #6 on: 11 April 2014, 12:35 »
RTec are seeing mad results from the KO3s (up to about 280bhp IIRC).  The issue I would then raise is whether you can put that onto the road? wheel spin would be mad I should think.
Depends what your aiming from from the car, bear in mind a rough guide of 300torque and above you'll be looking at internal upgrades...
VR Died...Now running MK3 Golf 180bhp 1.8T
Offline dom
  • Back in a Mk4
« Reply #7 on: 11 April 2014, 17:05 »
R-tech claim 260bhp from a KO3s with supporting mods including water meth.
Offline shaft69
« Reply #8 on: 11 April 2014, 20:52 »
As above I got 247hp with ko3s with wmi biggest increase was tq 292lbft.
184 Wallgate, Wigan
WN3 4AL
07966492823.
