Author Topic: Speedo Sensor Location  (Read 1531 times)
Offline jamiesgolf
« on: 10 April 2014, 11:39 »
Hi, I recently changed the clutch on my 2.0l mk4 golf GTi and ever since the speedometer hasn't worked. I presume i've missed plugging a sensor back in somewhere but does anyone know exactly where it is?
thanks in advance!
Offline jamiesgolf
Re: Speedo Sensor Location
« Reply #1 on: 10 April 2014, 17:53 »
« Last Edit: 10 April 2014, 17:54 by jamiesgolf »
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 10 April 2014, 22:08 »
thanks in advance!
The vehicle speed sensor is located at the back of the diff housing towards the front bulkhead (black topped unit with a plug going into it  usually the wiring loom is wrapped in a heat resistant jacket) simply plugs in and the sensor can be removed but be careful as its mostly plastic
2000 Mkiv GTi 1.8T AGU
Offline jamiesgolf
« Reply #3 on: 11 April 2014, 12:43 »
Awesome thanks, I'll have a look later. Cheers for your help
  • "1.8T AGU"
« Reply #4 on: 11 April 2014, 21:54 »
No worries hope you sort it :afro:
