Author Topic: MK4 Drilled Rotor HELP  (Read 1384 times)
Offline addzyy20
« on: 10 April 2014, 00:53 »
was noticing a knocking earlier while driving very very slow, slightly rolling, tapped the breaks and im getting a knocking moice which actually feels like my wheel is lifting.!
it had Drilled rotor discs, with no screws in.. However I cant see screws causing this
GOLF MK4 GTI T 150bhp Sreg
Offline dom
  • Back in a Mk4
Re: MK4 Drilled Rotor HELP
« Reply #1 on: 10 April 2014, 10:27 »
The knocking could be any number of things tbh, ball joint, tie rod, wishbone bush, arb bush
Offline addzyy20
« Reply #2 on: 10 April 2014, 14:31 »
Thanks for the reply mate. Got a feeling it could be driveshaft catching as I break causing the feeling of it lifting.. But then again it could just be a bush like you said..
Offline dom
  • Back in a Mk4
« Reply #3 on: 10 April 2014, 16:33 »
Are you lowered?
Offline addzyy20
« Reply #4 on: 10 April 2014, 18:10 »
50mm back 40mm front I believe. But I checked over it today and I brake then the wheel jumps forward slightly. So maybe wishbone arm..
