Author Topic: building an 8v gti engine  (Read 2284 times)
Offline Craigwilson
« on: 09 April 2014, 00:37 »
baisicaly I'm rebuilding a used engine I have, apparently it was mechanically sound and it doesn't look like there was anything wrong with it on the inside but I plan on replaceing all the bearings, piston rings and valve springs ect
this is what I have, one of the old pistons and rod just to look at,
as you can see there, is that a bearing in the small end of the rod ? and can it be removed and replaced?
and it's soon to be going into mine because my small ends are tapping,
also welcoming advice on rebuilding an engine as I haven't done it before
Offline Ben@VWH
Re: building an 8v gti engine
« Reply #1 on: 09 April 2014, 09:52 »
It's not so much a bearing, more of a bush. Well worth replacing. It's actually available sperately from vw under part no- 026-105-431. You must have a machine shop fit these for you as they must be carefully pressed in (easy to damage as its bronze), then it must also be honed to match the gudgeon pin.
 :smiley:
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 09 April 2014, 11:21 »
And unless you've kept a check on which pot the pistons etc have come out of you're unlikely to get a good result...
Offline Craigwilson
« Reply #3 on: 09 April 2014, 13:57 »
Yeah the other 3 are still in the block at the minute, I'll keep that in mind!
am I aswell sending the block to a machine shop?
Offline Organisys
  • Old and Slow...
« Reply #4 on: 09 April 2014, 14:06 »
Short answer, Yes.
 :grin:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #5 on: 09 April 2014, 14:31 »
Enjoy 54 videos of a mechanic stripping and rebuilding a complete 8v engine.
https://www.youtube.com/channel/UCqkrffHBdpIpQewqPPLGEzA
 :smiley:
Offline Craigwilson
« Reply #6 on: 09 April 2014, 15:31 »
I've seen that, Barry that does it, found that very good actually
