Author Topic: MKIV GTI engine racing and cutting ou  (Read 1420 times)
Offline sillygilly
« on: 08 April 2014, 12:58 »
Help, I have an 02 plate GTI that plays up after a long run or if i drive it hard.
It normally starts by over reving and then just cuts out.
My mechanic has thrown the towel in  :sick:
Offline matty james
Re: MKIV GTI engine racing and cutting ou
« Reply #1 on: 08 April 2014, 13:01 »
 :whistle:  have you had it scanned on vag com ?
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline sillygilly
« Reply #2 on: 08 April 2014, 13:02 »
Nope , what is that ?
Offline matty james
« Reply #3 on: 08 April 2014, 13:08 »
has your mechanic looked at the fault codes using vag com .(the onboard diagnostic system)
Offline sillygilly
« Reply #4 on: 08 April 2014, 13:14 »
Sorry yes. Sometimes it says its burning rich but thats about it.
Its bizzare , it drives brilliant until I open her up or dribve for a couple of hours. She settles down after a couple of days.
Offline matty james
« Reply #5 on: 08 April 2014, 13:21 »
get him to print the fault codes off and then post em up here , that way someone will tell you whats wrong . sounds something simple though  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 08 April 2014, 14:59 »
Top mechanic by the sound of it...
Running rich could be a a number of things, usually the lambda has something to do with it though. If it is you could be well on the way to needing a cat as well
