Golf mk4
Wazzzer
Help with forge intake needed
Topic: Help with forge intake needed (Read 1261 times)
Bfstrachan
07 April 2014, 19:05 »
I bought a used pipe and although it's in good shape the small alloy pipe connector at he turbo end is missing. Does anyone know how I can get a replacement one?
Thanks!
daz veedub
Forum addict
Operation 1.8t bolf
Re: Help with forge intake needed
07 April 2014, 21:46 »
Contact forge they may be able to sort u out : )
Dalo Harkin
08 April 2014, 08:16 »
Its only to join another pipe to, you can use a plastic tube for what it does, if Forge don't sort you out get to B&Q or Halfrauds
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Bfstrachan
09 April 2014, 08:12 »
Sorted! Managed to get a joining piece from a local supplier. BTW, fitting the pipe was a bit of an adventure! Glad to see it all together. Just the rear box to fit and will be ready to turn the key
Thanks!
Golf mk4
Wazzzer
