Author Topic: how to fit fog light switch?  (Read 969 times)
Offline dasachmo
« on: 02 September 2005, 15:59 »
hi, its a bit of a noob question, but how do you fit the fog light switch, and also, i have 2 dummys in ma golf, ( mk2 1.3), i can't just make one of those dummies a real one can i? am i right in assuming they can't be changed to blank working switches?
Judderi
Re: how to fit fog light switch?
« Reply #1 on: 02 September 2005, 16:02 »
The blank swithches are just bits of plastic. You can replace them with a real switch.
Offline GTI EDITION (aka LTD)
« Reply #2 on: 02 September 2005, 16:09 »
Your fog light should have two positions ,the first being for front fogs the second for front and rear fogs.
If you look at the wiring loom in your engine bay , just below the expansion tank you should find a two pin plug which are the live and earth for the front fogs , just extend the wires from the lamps then plug in and play :wink:
hope this helps
 Ãƒâ€šÃ‚                    Oli :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline dasachmo
« Reply #3 on: 02 September 2005, 16:12 »
cheers, what about if i want to do hazards, or a single flick switch?
