Jesus you need your own Thread I think try search bar or even google!!
http://forums.vwvortex.com/showthread.php?1312975http://www.golfgtiforum.co.uk/index.php?topic=215370.0 Posted 03 November 2006 - 08:43 AM
OK Mate
here is a list of tools[
Philips screwdriver
small flat head screwdriver
17mm spanner
YUP thats it mate
Step 1:
Remove the FRONT A post trims by getting a good grip of them and pulling outwards
Step 2:
Using the flat head remove the plastick cover on the light console in the roof and there you will find 2 phillips screws(remove)
Step 3:
Pull down the handles in the roof and you will find 2 caps that will open with the flat head and behind that are 2 more phillips screws
the same process is used for all 4 grips.
Step 4:
Using the flat head screwdriver prize open the covers from the seatbelt on the B post (THEY OPEN UPWARDS) and undoo the 17MM bolts, this process is the same for all 4.
The trim wil pull of the same as the front ones.
Step 5:
Open the boot and on the top of the roof lip you will fina a thin long plastic trim that you need to get a good grip of and pull downwards
THE ROOF IS ALMOST FREE
Take off the tops of the door rubbers by pulling down on them but you only have to do it enough that the roof is free so not all the way off.
giving it a tug and a wigle about should loosen it enough so you can see all the wores that are glued to the roof
(LOOK ON THE PASSANGER SIDE A POST YOU WILL FIND A PLUG NEAR THE DASH THAT YOU CAN DISCONECT FOR THE ROOF LOOM)
