Author Topic: Adjusted Shock Absorbers  (Read 2801 times)
Offline LJS7
« on: 01 April 2014, 22:03 »
Hello
Since I got the GTI back in November I noticed intermittent mechanical/grinding noises coming from the front wheel areas whilst turning at slow speeds (manoeuvres etc).
Took it into VW last week and apparently the shocks were clipping so they adjusted them.
The noise has pretty much disappeared except at full lock.
My brother got his GTI a couple of weeks back but when i took it out yesterday I noticed a similar noise, if not worse.
Is it feasible that the shocks could be catching / rubbing?
Thanks
MK7 GTI | 3dr | Pure White
Offline peterdoherty
Re: Adjusted Shock Absorbers
« Reply #1 on: 01 April 2014, 22:15 »
sounds more like the earlier issue of the transport blocks on the shocks not all being removed
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline monkeyhanger
« Reply #2 on: 02 April 2014, 07:35 »
Or a seized shock mount bearing that isn't allowing the shock assembly to pivot properly.
Offline Skinnee D
« Reply #3 on: 02 April 2014, 08:41 »
I had rubbing / creaking noises from the steering as part of the shock mount problem that also included a grinding noise on full lock.  Replacement of both shock mounts and their bearings fixed it.
GTD + 3 pedals :-)
Offline GiT1984
« Reply #4 on: 02 April 2014, 15:47 »
I'm getting a bit of a "clonk" over bumps / small potholes - is this normal?
2014 Mk7 GTi - CSG, PP, Leather, DSG, ACC, Pro Nav, Dynaudio, Reversing Camera, Rear Airbags, Winter pack.
2013 Porsche Boxster S
« Reply #5 on: 03 April 2014, 13:45 »
Nope – are you sure the transport pucks were removed by the dealership?
Offline corgi
« Reply #6 on: 05 April 2014, 18:41 »
Adjusted?
What adjustment is there? Ask them to be specific, I'd be very interested to hear...
Corgi
